Hi, I have a 454/330 Mercruiser. I was going to look at the oil leaking (not bad) from the valve covers, maybe tighten them down a little or change the gaskets. I found they were really tight in some places, too tight, and pretty unsnug in others, like someone (the PO) had been fooling around with it.
Ok so far, but one of the bolts, at the rear of the engine on the starboard side, is stripped. It won't tighten, but it seems like it will loosen out, if I'm careful. So, I'm wondering (it's hard to get to, with the exhaust right there) what I can expect to see. What are the chances of it being just the bolt, and not the block that's stripped? If maybe the bolt ws softer than the block? Has this happened to you before? How did you fix it? Thanks, Pal
