Keithm18
Hi Guys. I need your help please.
in my search to confirm if my carbs had the right jets for the new altitude, like an idiot i tried to install a jet at the wrong angle and stripped the aluminum carb threads.
1991 200hp V6. On the top carb there are two jets, one on either side of the carb. Known as progression air jets in the diagram. I removed one and when putting it back managed to cross thread it. When it wouldn't tighten down i removed it and found strands of aluminum that used to be threads in the carb neatly wrapped around the brass jet.....
When I look into the carb i can find see some threads remain, but they are deeper than the jet and where the jet makes contact there are now no threads.
i've been reading up on where guys have used all sorts of material to try and "make threads" using all kinds of epoxies/glues/jb weld. I tried myself with a little liquid metal, but the whole space is so small it never worked.
I'm sure i can glue it ok, using the liquid metal or some equivalent, but i am worried that at some point it works loose and the motor swallows it down the carb throat....
i've tried to find a replacement carb, but these WMA 1's are rare and hard to find.
does anyone have any ideas for me???
P.s. I already know i'm a moron for this one.....
