I have a 86 Mariner 25hp (Yamaha) recently rebuilt, honed, and re ringed. Compression is around 120 on both. Rebuilt the carb. New coil pack and cdi unit. New plugs also. I checked and set the timing at 25 degrees. Also played around a few degrees both ways. Pumping primer bulb does nothing. Opening gas cap on tank also no change. All new fuel lines and filter. New lines are semi transparent so I can see no air bubbles.
The crazy thing is I know the motor will hit 5k on my boat(14ft fiberglass skiff) because it’s done it before when I first purchased it. Then over time it has consistently stayed around 3800 rpms.
Starts and idles perfectly. Has decent acceleration up to about 3000 rpms and then levels off and stays between 3500-3800.
Unfortunately since my rebuild it has developed a ticking noise. Most noticeable at idle. Could this be the New culprit robbing me of power?
https://www.youtube.com/watch?v=YoDh5jHPPU0&feature=youtu.be
