Update -
I received the new parts recently and tried to do the job.
I managed to jack the motor up via that jockey wheel method and then removed the center tube.
The motor has dropped a little, and now I cannot raise it again because the tube is out. The motor is tied to the boat.
When I try to jack motor up the motor just slides out away from transom - on the blocks supporting the skeg, and does not rise.
I don't know what to do now.
The clearance between the bottom of the top member of an engine hoist and the flywheel is none, as it is about 70mm too short (to comfortably go over top of flywheel)...
I cannot obtain any higher hoist anywhere..
Help!
Cameron
Help!
Cameron
