dhearn0513
Took the Flywheel off my 1985 Evinrude 120 tonight, and there was some metal shavings all around the magnets on the Stator and Flywheel. I believed they may have shorted out and ruined my stator, because now I have no spark to any cylinder. Looked like the metal shavings were coming from a magnetized round piece pressed onto the bottom of the flywheel. I dont see this part in the manual though. Is this part of the flywheel assembly. Also the timing base looks good, but it as a small pin hole lose to the top on the side. Is this hole suppose to be there. Sorry to be long winded, here are the ? I need answered.
1 Would those metal shaving cause my stator short out?
2 Is the piece that looked pressed onto the bottom of the flywheel part of that assemble?
3 Is the pin hole in the timing base suppose to be there?
4 After replacing the timing base, does the WOT timing need to be reset.
