I've got an intermittent starting problem on my Mariner 50HP 1992 2stroke. Often it will start fine when I launch the boat, and goes well across the lake with lots of power. But when I try to start it again after its been OFF for a while (30 mins to 1.5 hrs) it just wont start. Starter is turning the engine, battery is strong, but it wont fire. I keep trying to start it for ~30mins (until the battery drains), then have to get towed back :-(
I've checked the obvious things:
Fuel bulb squeezed, and its hard, indicating there is fuel going up to the motor from the tote tank.
New spark plugs
2stroke oil tank has lots of oil in it
Tried with choke, without choke, with idle lever up a bit, or right up, or not up at all.
Tried turning key OFF, ON, many different times.
Then when its back at home, it starts first time (with earmuffs on in the driveway). Very annoying.
Its a 3-cylinder engine, and I tested each spark plug individually (at home) by unplugging 2 plugs at a time and seeing if the engine would start. It did start, for every plug.
Its somewhat difficult to troubleshoot it when I have the family in the boat and we're out on the water.
So I'm wondering;
1) What troubleshooting steps should I follow next time it happens?
2) What are the likely parts that would fail in an engine of this age, that I could proactively replace before I take it out again?
One guy said it could be a fuel pump issue, but would that cause intermittent faults?
New spark plugs
So I'm wondering;
