Floatation Device
I have a 1996 SeaRay 330 with twin 7.4 MIE's. Idles all day with no issue. Run on plan and the starboard engine stalls. Wait ten mintes, engine restarts and idles fine but will die again on plane. No set time for stalling. Carb is flooded which I believe takes the ten minutes to start. Switched ignition module, anti knock module, coil, between the engines, still occurs on strbd engine. Change fuel filter, rebuilt carb, same problem. Have ordered new fuel pump and switched the dist. sensors. Will test this weekend. Have not check if vent is clogged. Any other suggestions?
