"I have a 150 HP with about 70
"I have a 150 HP with about 70 hours total run time. About a month ago I had a very serious miss develop in the engine ( would not get on plane ). I took the boat to the dealer, they informed me that there were no trouble codes indicated, and that the problem was a bad plug (Denso skj20dr-m11) and that honda would replace under warranty due to lack of hours. Yesterday while heading across the lake the engine developed a serious miss and would not stay on plane. I idled back home and found that the top cylinder was not firing, replaced the Denso plug with a NGK I had purchased (IZFR6K116994) PROBLRM WENT AWAY.
My questions are:
Is there a problem with some of the IRIDIUM plugs, or my engine ??
What plug do you recommend?
I do not know which of the four cylinders the dealer replaced the plug on---
Do you have any suggestions?
Also --- I have performed the 20 hour oil and filter change. I plan to use Castrol syntec for the next oil change ------- I tried to perform a search on this subject ---but could not find any definite information pro or con."
My questions are:
