timguy
Silver Medal Contributor
Have a Merc 50 Classic. Spark dies when motor is run about 1 minute. It will restart after about 5 minute rest. After that no spark again unless you wait 15 min. It will only run for a few seconds but runs good, on all four cyl. Stator tests 1.5 thou ohms on low speed side, should be 7 thou or so, right? High speed side close to specs but 10 ohms down. Stator was replaced at one time but I don't have a good repair history. Switch box also replaced with a used one and looks like an aftermarket unit. Trigger tests fine. What do you think? I have a good used switch box but I'm hesitant to try it with the stator out of recommended parameters. Thanks, Tim
