"Dealer is correct. Your model
"Dealer is correct. Your model has a simple "Constant Rate" 50:1 oil pump. I has nothing to adjust, nothing to set, it either pumps or it doesn't on it's manufactured settings.
The extra smoke may be partially due to running the carbs a little rich, in addition to whatever the oil pump in contributing. You could try leaning out a bit.
However, everyone perception is subjective. How much smoke are you getting when running at idle?
You are creating a big cloud behind you, or you can just see/smell it (which you wouldn't at higher speed because you are moving away from the fumes quickly)."
