I have a 1996 Johnson 150hp motor that will not run past 3000 rpms. I've just had the powerpack replaced and I now suspect an issue with the shift interrupter switch. From everything I've read, my understanding is that when the shift interrupter switch is depressed (circuit closed) the motor will run on only 3 cylinders. My motor is the exact opposite, it will only run on 6 cylinders when the switch is closed.
To confirm this, i've pulled the ground off of the switch and the motor was stuck in 3 cylinder mode. I've also had the motor bulking at 3000 rpms and closed the switch with my hand (with the ground re-connected), and the motor smooths right out. Can someone tell me 1) If the motor should run on six cylinders with the switch open and 2) assuming mine is working wrong, could my switch interrupter wires be crossed?
Thanks in advance
Thanks in advance
