mikemonte61
Greetings all.
I continue to have a rough running, hard to idle 200 hp mariner 2 cycle fuel injected. It fires and runs rough when cold but after a few minutes it get hard to start with extremely low idle. Dies when I put it in gear. It seems to run ok once I get it up and running across the lake. I have recently ran it out of gas
Repairs/ parts I have replaced include:
1. 6 coil packs
2. switch blocks (2) Sierra
3. spark plugs
4. complete fuel line & cleaned the tank
5. Compression test: 3 @ 135, 3@130
6. primary fuel pump diaphragm(s)
7. The existing injection fuel pump has 23 lb, 20 second time-out with ignition on.
8. All cylinders a firing with bright white spark and are consistent.
9. I confirmed the fuel oil mix by color against a known 50:1 mix in identical glass jars. Quicksilver oil & non-ethanal 91 octane gas
I am now leaning towards a fuel inject regulator. Does anyone know how to test the regulator or is there something else I should be testing?
Thanks for your help.
1. 6 coil packs
3. spark plugs
