Wayne Newman
I think I may have found the problem with why my Crusader 350's (1992 Silverton) are hard starting, especially when they have been sitting for a few days. I've got the choke assembly that has a coil spring that's mounted directly to the intake manifold, with the choke linkage attaching through a small 'loop' in the choke spring. While looking at them today, I see that on both engines, the rod that attaches the choke spring to the manifold bracket (the rod goes right through the center of the choke spring) is loose and spinning in the bracket. It looks like it was originally crimped to the bracket and it has come loose.
I reset the location of the choke spring so that when the choke linkage is attached, the carb choke plate is firmly closed when dead cold. At this position, I re-crimped the rod to the bracket with needle nose pliers. I've got a feeling that this won't be enough to hold it permamently.
I'm wondering if anyone else has found this problem.
Also, I wonder if I should put a little epoxy on the crimped joint? I'm not sure what else I could do. Maybe if I removed the assembly, I could solder the joint?
Thanks! Maybe this will help someone else check for this same problem.
Wayne
Wayne
