For what it's worth..... In addition to my last post which pertains to the installation/rotation positioning of the impeller....
Even the most experienced outboard technician, when working on any outboard regardless of its make or horsepower, will at times encounter moments when he/she will turn the engine over backwards (counter clockwise). This might be to check for an evasive/intermitent tick, click, knock, tap, whatever, or simply to inspect some internal portion of the powerhead for example. This is nothing unusual.
Obviously, when this counter clockwise procedure is performed for whatever reason, the impeller is being turned in the opposite of its normal rotation. This creates no problem as the impeller is a flexible component which sets within a housing where the center of the impeller is offset. As such, the impeller blades are in a curved compressed position within the housing for a portion of its rotation and near fully extended for the duration of its rotation.
Due to the design of the water pump assembly as stated above, regardless of what direction the flexible impeller blades might be facing, as soon as that engine starts, the impeller blades will flex into their proper operating position.
This is assuming that the impeller was not shipped over on the Santa Maria which has most likely caused it to encounter a non flex rigor mortis like condition.
