moresparks
HI, Has anybody had installed new Mercruiser 4.5L Sterndrives?
I am seriously thinking of re-powering from 2 aging straight 4 Volvo’s, but I am confused regarding the specified dimensions.
The old Volvos are fairly compact but they are a tight fit height-wise. I have around 800mm height in the engine locker at the front – tailing off slightly towards the transom. Now.. the overall specification of the Mercruiser says that it is 559mm high, but – when you look at the installation drawing it shows a height at the centre of the flywheel as 567mm with a 2” riser then about 242mm below the flywheel. This gives a height of 809mm and that is not counting the installation position.
So I am just at the planning stage now and need to remove the old drives and engines etc, before preparing the locker, beds etc
I am doubtful two 4.5L’s will fit and looking for basic guidance before the expense of engaging the engine suppliers. I could go to a single 6.2L 350 hp which I know fits in a similar boat (a 27 foot Targa Cruiser), but like the idea of Twins due to the waters I sail in.
Thank you.
Thank you.
