Replacing the high preasure fuel filter
easy82
I have a 2012 90hp fourstroke the manual says i need to have a mechanic to replace the high preasure fuel filter because it requires special tools. Can I do this myself and if so how.
chawk_man
Silver Medal Contributor
What brand of 90?
All Honda four-strokes that I am familiar with make it fairly easy for the owner to change the HP fuel filter. On my 225 it takes a 10 mm wrench and removing three bolts. Furthermore, a very significant percentage of performance problems with a four stroke outboard can be traced to the HP fuel filter or VST.
easy82
My four stroke is a mercury the high preasure filter is an inline type and is the same as the low pressure filter. The high preasuure side has a schrader valve located on the top of the moter to bleed the preasure off the line.
chawk_man
OK. Recommend that you post your question on the Mercury Outboard forum on this site. Go to the top left of this page, click on "Forum Home" and select Mercury Outboards.
