divemaster
Already tired of winter & ready to work on the boat. I have a 92 Regal 240 with a Volvo 570dp and need to replace the control lever and cables. Teleflex replacements with the tilt/trim switches on the handle are hard to find and expensive. Evidently, Volvo has a special wiring configuration (5 wires) that is odd. I am thinking about buying the controller that only has the trim on the handle, which is much easier to find and $100 less. I have an open spot on the dash for a rocker switch, which I could put a tilt switch in. Oddly enough, the label below that slot is "tilt."
Has anyone done this? Looking for advise on if it will work. In my mind, it shouldn't matter where the switch is located so long as the wiring is configured the same. Thanks for any suggestions.
