Removing oil mixer pump
I want to mix my own fuel, and rely on a system that will fail sooner or later. I've been told two different opinions. 1. Just disconnect all hoses and(cap off)from the main reservoir, and unplug alarm. 2. Same as 1. Plus remove shaft from oil pump.
[h=2]
Re: Removing oil mixer pump[/h]
I want to mix my own fuel, and rely on a system that will fail sooner or later. I've been told two different opinions. 1. Just disconnect all hoses and(cap off)from the main reservoir, and unplug alarm. 2. Same as 1. Plus remove shaft from oil pump.​
Why are you removing the pump? Is it faulty? Are you replacing it with new part?
