Popeye_1425
Greetings. I'm having a fit trying to get a tach to work on my 1980 Johnson. It did not come with one from the factory apparently.
What I've done:
Bought a cheap tach (1st mistake) and wired it correctly. Did not function. Tested the rectifier and it tested bad. I was getting readings in both directions on the ohm meter from both yellow wires.
I replaced the rectifier and tach worked as long as I held my finger down on the positive lead that connects to cheap tach.
Bought a Faria marine tach. Connected correctly and pole settings are as described in the directions but tach does not function. I put the cheap tach back on and it did not function. There is power to the tach. It appears as if the tach is not getting information from the gray source wire that ties into the rectifier at the junction bar.
Using a Cen-Tech Multimeter set at 200k diode I tested the new rectifier. When I place red lead from meter on each yellow wire and the black lead from meter to rectifier case, I get reading of 1 on both yellow wires. Which I should. (Right?) When I switch the black lead from the meter to each yellow wire and the red lead from the meter to the rectifier case I get two readings. One yellow wire measures at 84.5 while the other yellow wire reads at 64.9. both readings seem stable. Is there too much deviation between the two yellow wires readings? Is this causing my issue. If not, where else should I starting looking? Any input would be much appreciated.
What I've done:
