hi, i have a 1990 454 merc cruiser engiine that i had rebuilt from a good rebuilder this engine came out of this boat and was running just tired like it's owner.i put engine together and i installed in boat. this is about 4th engine i did and never had a problem.i have a thunder bolt ignition which i checked by the book and it checked out ok.i had a mechanic come over and check valves and timing and was told my distributor was the problem even though i had spark at plugs. i got a auto, one wire hei distributor and tried that got same will not fire on turning over.the engine turns cw and the distributor also had no 1 tdc, rotor pointing to no.1 plug and 1 on distributor,all gas lines,filter,pump and tank were replaced or cleaned. i took off timing chain cover for mechanic to look at to check timing marks with no.1 piston up he said it was ok. this engine turns over ok.and i get good spark. just covered for winter, had dusting of snow if i get a good day i will look at it this winter. i would like to get this engine just started to have for next season. any help would be great thank you
