I'm looking for advice on a 1972, 65 HP Johnson as I rebuild it this winter. Last summer, it tried to throw a connecting rod and seized. The crankcase is apart, all the internals/pistons are removed and inspected. The cylinders do NOT need to be re-bored. I will replace the crankshaft, with all new bearings except for at the wrist pins, new rings, seals, gaskets and 1 replacement piston with connecting rod attached. I have the "Clymer's" and "Intertec" (generic) repair books, but as that I do NOT fully trust them, I have STOPPED work and will wait for arrival of the actual Johnson shop manual.
Questions:
(1) For motor break-in after rebuild, Clymer's (Intertec is silent) requires a 10 hour run at half throttle (2500 rpm), in a test barrel, with a "test-weight propeller" (whatever that is). The duration seems excessive to me, and not varying the rpm does not make sense. And I would imagine to change the fuel mix when breaking it in (from 50:1 to heavier, 25:1?) is probably a good idea, but no guidance...
(2) The exhaust plate is NOT off the power-head, as it has 6 (out of 19) frozen bolts. Clymer's wants this plate off so that after re-assembly, I can ensure that the rings are properly seated, springy and not rotating in the grooves. The benefits of taking this plate off vs possible damage to the power head, stripped threads etc.... Is removal worth the risks?
(3) The air intake plenum to the carbs: As found was filthy, oil, dirt, seagull feathers! ....tiny bits of cowling sound-proofing foam, probably salt water spray.... Is this motor supposed to have some kind of air filter? I see no mention on my books or any on-line sources (exploded views, etc) for one. I plan on fabricating and installing an air filter after I get it running (I know it will affect the fuel mix).
(4) I have matched all the new upper (compression) piston rings, per cylinder, so that the gaps are within tolerance (0.007" to 0.017" gap). However, ALL the new lower rings seem to have a slighter looser fit (0.020" gap) when fitted. The book does not differentiate or specify a an upper vs lower ring gap tolerance. It just states "ring gap 0.007 to 0.017". Do I have the correct lower rings? (Kinda makes sense to me that the lower ring, which does not handle full compression like the upper, should be slightly looser to allow lubrication and keep the piston centered, that's its purpose... Or am I just justifying?)
(5) I plan on using Scotch pads to break the glaze on the cylinder walls and NOT a drill powered hone (I don't want to risk smearing the metal around the intake/exhaust ports ....or break the hone on the ports). Good idea? The bores are OK as is for STD rings by local machine shop check, not excessive taper, out-of-round, etc.
(6) I plan on using blue Loctite on the connecting rod bolts as that was what caused the initial failure. Good idea?
(7) Clymer's OKs and I plan on using Vasoline (NOT automotive grease) to gob all over the new bearings as I install. The gasoline/oil mix will dissolve the Vasoline as it runs. Good idea?
Thanks!
Eric, CT
Questions:
Thanks!
Eric, CT
