theydrewa31
Hello All,
I am in the process of a restoration on a Starcraft Islander 221V. The hull is aluminum and the outdrive is an OMC Cobra.
When I was at the Marine parts store the fella there said that Moeller spray cans were the best and only options for repainting the outdrive, so I picked up some cans while I was there but can easily return them. I have taken it down to bare metal and I am ready to paint.
I have a nice paint sprayer, a large compressor and experience painting cars. I would prefer to simply use my spray gun as it performs far better than any rattle can I have ever used. Is it alright to use automotive paint on the outdrive and the aluminum hull? I would of course make sure that the paint does not contain copper. As the outdrive has been taken down to bare metal I would be using a high build primer, then paint, then 2K clear coat (the kind that you mix hardener into), finished with cut & buff for a nice shine (just like we do on cars).
For the hull I am simply covering up some spots where the rollers have taken some paint off over time, and some spots where I had some welding done on the transom, so I will not be painting the entire hull. For that reason, I was considering skipping the clear coat since it would be difficult to blend to the existing paint. Let me know if you think its better to top coat with 2K clear coat on the hull? I am trying to avoid buying that insanely expensive paint in the marine supply store, which I feel is somewhat unnecessary since the boat will be trailered when not in use. At most the boat will spend a few days on the water for longer trips to the offshore islands. The boat will be used primarily in saltwater if that makes any difference.
Thanks for any help Gents!
