highstakes
Re: 2001 Evinrude 225 Ficht
Does anyone know how to troubleshoot the Fuel lift pump on this motor???
Having a startissue. Will spin but not start. Put an inline light spark tester on Light fires on all cyl. Working onow with fuel problem. NO faults when computer plugged in. Before motor just spun. NOW spins several rotations and just STOPS, like a hard UMPH... Restart does the same. Going to drain fuel and new filter. Will also check fuel pressure.(20-30 PSI) Any suggestions are helpful... Mike StakesDoes anyone know how to troubleshoot the Fuel lift pump on this motor???
Using the bulb i can pump fuel past lift Pmp. to filter input. Removed fuel input to to V sep/f pmp. using bulb It wil slowly flow fuel into V Sep.. Remove fuel out line of fuel pump.. Try to start using key, Fuel will flow out, BUT with all hooked up I only show appx. 4/5 PSI at test fitting... Also checked fire at plug using a spark tester set to appx. 1/2" Good spark. Will hook up software tomorrow and start checkout of fuel pump/ Injectors. One other thing is the fuel pump VS just held by the single C clip??? Thanks for letting me ramble..Does anyone know how to troubleshoot the Fuel lift pump on this motor???
