BomoFormula
1994 Formula 252ss. Mercruiser 7.4l bravo 3 tb4
This intermittent issue has been plaguing me for almost 3 seasons. It’s taken most of the relaxation out of my boating. I’m getting desperate.
Here's the problem:
The boat starts/runs/idles normally. There’s a “random” stalling issue. It will stall at idle, under light throttle, at heavy throttle. It will randomly stall when hot or cold. I cannot get it to stall at will or regularly. It's not a fuel issue.
When it stalls there is no sputtering, it’s as though someone just cut the power. There are no blown fuses to or breakers tripped. It’s gone days or weeks without issue, only to return and stall multiple times a day.
The dash instruments all go dead, but every accessory still has power, (radio, blowers etc). Within 15-60seconds power returns to the dash and the motor will crank and fire up as normal. It may stall out shortly thereafter or not at all.
I replaced the eta ignition breaker last year. This seemed to fix the problem for several weeks, but then it returned.
I bypassed the kill switch, it made no difference
I disconnected the tach, no difference
I cleaned all the grounds and it seemed to work for a few weeks, and then it started stalling again.
I replaced the ignition switch, no change. Still stalling.
Jiggling wires or throttle makes no difference when running
Plug wires, coil, sensor in distributor, cap/rotor, and battery, have all been replaced.
I had had it at the shop, and they cleaned the banana plug connections and also jiggled everything but couldn’t get the boat to stall.
I figure it’s something in the ignition circuit, but I’m at a loss.
Could it be the ignition control module? The 50amp breaker at the starter going bad? Breaker on the engine? Voltage regulator going bad?
What would cause a loss of power to the dash, not trip breakers, and then disappear.
I just put her in the water today and I’ve got to solve this.
Thank you.
Here's the problem:
Thank you.
