crankbait
i recently put a 87 90hp with a dual ram lift and tilt on my boat. i am having a problem with the tilt gradually bleeding down. i used 30 w oil as instructed in this forum. the strange part is......the engine will lift up and down fine. i even did a test, by leaving it in the upright position for three days. now...... it gradually bleeds downs. while it is bleeding down.....i can hear it bubbling back into the oil resevoir where the pump is . any suggestions on what/where i should start ?? is there an adjustment i am overlooking ? there is a big serrated thumb screw on the side of the pump motor, but it does not seem to make any difference wether it is adjusted all the way in or out ??
