RicardoMarine
Gold Medal Contributor
I am very familiar with the Volvo Penta cone clutch system, of which Merc gained the copy-rights to just prior to the introduction of their B drive.
Very similar to the Volvo Penta transmissions, within the Merc B drive cone clutch system you'll have a conical shaped sliding sleeve and two corresponding conical shaped gear cups... one above and one below the sliding sleeve.
These two gear cups (SEQ # 23 ) rotate when ever the engine is operating.
The sliding sleeve (SEQ # 25) is splined to the vertical shaft, and is static until a gear selection has been made.
Note the steep cut spiral splines on the vertical shaft (SEQ# 27).
The same shaped splines are found within the sliding sleeve.
These steep cut splines cause any sliding sleeve/gear cup friction to cause further engagement, until enough friction is gained to create complete lock-up.
Much like the principle used on a twist style EZ Out bolt extractor...... (I.E., the more resistance, the more lock-up until both rotate 1:1.)
The conical shaped gear cup surfaces are smooth.
The sliding sleeve friction surface is machined with oiling grooves, both perpendicular and concentric with it's friction surface.
These grooves allow the oil to escape gently as the surface gently comes into contact with the rotating gear cup creating a gentle lock-up..... yada, yada, yada and so on.
While the B drive does not use a Volvo Penta style eccentric piston and shift shoe, it does incorporate and shift plate, of sorts, that lifts and lowers the sliding sleeve into contact with the corresponding and rotating gear cup.
Just as with the Volvo Penta system, the sliding sleeve is static (on either a running or non-running engine) until a gear selection has been made.
The Volvo Penta sliding sleeve can be operated statically without causing any damage.
Merc says that we should never make a B drive gear selection unless the engine is running.
So now the question:
Would one of you be able to explain why Merc does not want their cone clutch system operated with a non-running engine?
IOW, what is it that could cause damage if a gear shift was made while the engine is not operating?
I am curious!
I am curious!
