question for boatin bob
rcahill31
Bob, when one uses the dwell meter after your points and etc. are replaced is there a certain engine rpm used to read the dwell deg.?
I'm not Bob, nor do I play Bob on TV. But I can pretend to be Bob for a mintue here. :)
No offense, Bob!
I can tell you that setting dwell at/around idle RPM should cause no change intrinsically.
You may see a change to dwell at higher RPM, but we are not setting dwell at anything other than low RPM.
Dwell is nothing more than the coil saturation duration of a given cylinder's total dedicated points cam angle measured in Degrees.
IOW's, a V-8 points cam offers a total of 45* (360 divided by 8 = 45) for one cylinder's worth of coil saturation and field collapse! (I.E., spark)
If dwell is 31*, that leaves 14* open.
Things that may affect, or change, dwell angle may be a weak points spring, or distributor shaft wobble due to worn bushings, etc.
If this occurs, you may see a more progressive change to dwell as RPM increase.
If severe enough, you may see this at low RPM.
It's a good sign that your distributor needs attention and/or replacement.
I know that's more than you asked for, but I hope that helps.
Thanks Rick!!!
Couldn't have said it better myself...infact I wouldn't have said it that well. It would have been something like at idle or around 600-650
By the way...my toes are just fine :D:D:D
Bob, thank you for confirming that, and glad that your toes are OK. :)
I wouldn't have cared if you had done same had I been "pinged", and you jumped in!
We're all here to help!
