oldschoolnc
Hi, I am in the middle of pulling my pwrhead to install solid mounts. I removed all the bolts and nuts I can see, won't budge. Fresh water motor, bolts came out with fingers, once loose. Lower is still on, but was just put on last week, so it shouldn't be stuck. I have pulled quite a few crossflows, but this is my first looper..... I can see when it was last installed they used some type of gasket sealer. I am pulling up enough that i started lifting the boat.(a Hydrostream) I tried to carefully drive a sharp 1" chisel between the block and exh adapter. I don't want to do any damage. are there any bolts, nuts that I can't see? Where is a good spot to try and pry? I tried all four corners. I tried rocking it strongly. What's your trick? Am I wrong in thinking I can pull it with lower still on? ANY ADVICE WILL BE GREATLY APPRECIATED!!
