christopher1573
I know there is never a simple answer to this one however I am going to be re-propping the 225 fitted to my 22foot rib.
The Rib weighs about 1500KGs without any passengers so with 3 up about 1800kgs. I am currently getting a miximum speed of circa 50mph which is not too bad although on my last rib which was exactly the same type but 2 feet shorter and maybe 150kgs lighter I used to get the same speed with an E-tec 150 running a 19" Stainless Viper Prop.
Sooo..
I am currently running a 21" Laser II Prop and I believe I am seeing between 5-5,500 RPM fully timmed out at full throttle (need to fit new tacho). The laser has the large hole vent bungs fitted.
My midrange cruising is the bit I am most concerned about as fuel consumption is IMO too high. THe Evinrude used to give me about 1 litre per mile at 30-35 knots. THe Honda gave me about 1.5-1.6 litres at the same speed.
I read this article http://www.boatpoint.com.au/features/2002/honda-bf225-vs-yamaha-f225-8434 which was interesting and seemed to suggest a larger diameter prop is better for the Honda due to its larger and less efficient gearbox design. The laser I think is 14" diameter so I guess perhaps something like a Mirage at 15 1/4" by maybe 19" pitch might be a better bet?
I have just raised the engine a couple of notches too so first things first I am going to fit the new RPM gauge then run some trials with the current prop. I also have a set of vent plugs that block off the holes on the Laser to try as well to see if this makes any difference.
I will post the results when I get a chance to take the boat out however if anyone can share any suggestions I would be grateful !!!
Chris
Sooo..
Chris
