G,day,
Thank you admin for the join
i have a prop question
i have a mercury 1150 1971 115hp.I originally had a 13x19p alloy prop fitted to the motor but after having to remove with heat the rubber is now spinning under load.
i have since brought a second hand quicksilver laser 2 14x20p and modified thrush washer off old prop as i never got one with the prop and also had to file away a part of the trim tab for clearance it all fits good.i have seen that the later 115hp mercury big foots have a 14 inch prop so I'm hoping there should not be any other issues?
ps after reading mercury prop guide going from alloy to stainless i should go up 1 pitch size for flexing of the alloy prop i,m just worried about the diameter change
thanks Stu
i had to reseal prop main shaft and put some new bearings in the gear leg as it has been in the water for years also worked on the motor head.
thanks Stu
