I have a 2005 23' 5000lb Monterrey, I have recently replaced the original 305 MPI Alpha 1 Gen 2 with a 383 MPI and a Bravo 1 with a 1.5 gear ratio.
The 305 prop was a 4 blade Solas 14/1/8 x 19. The Bravo drive i installed already had a Mirage 3 Blade 14 3/4 x 21 on it, it was hooked up to a 496 in its previous life. I also have a Power tech 14 1/2 X 16 that i have never run and an Aluminum Hustler 14.5 x 17.
I took the boat out for sea trial with the 3 blade on it, it comes outta the hole pretty good, but would only pull up to 4000 rpm and GPS speed was 48mph. Are any of the props the right size for my application? I am looking for a good all around prop, strong out of the hole with decent top end.
Just looking for opinions from you guys that have been doing this for awhile.
By the way, these forums were the ONLY way i made it through that complete motor and outdrive swap, thank all you guys for that!
