Jkcckc2002
I purchased this motor a while ago to repace the 35hp i had. This one had power trim and the older one didn't. Purchased it knowing it had low compression on all cylinders. Decarbed it and got compression up to 135 on all 3. Had a water leak in the #3 cylinder and i was going to replace the exhaust cover gaskets only. When i pulled tbe covers off the pistons were scored so i decided to rebuild it. Honed the cylenders, new pistons and rings bearings seals the whole 9.
So no i have everything back together and on the boat. It has new water pump, new fuel pump kit, and new cab kits in it. I have done the link and sync numerous times and cannot seem to get it to idle now enough. The timing and throttle pick up settings are giving me a hard time. Another thing is, I have One manual i have said the carb jets were in the wrong places, and another said they were correct.
If some one had some experience with thks engine or the mariner twin of it, i would apretiate the help.
John
John
