I have a 1985 Evinrude 150hp v6. I noticed the primer solenoid doesn't always click when the key is on and the key pushed in. Its been intermittent. Will this cause my gettingvstranded issues and the motor intermittently not starting at times?. So if it doesn't click its not working right? So to check it can I run a jumper from the positive battery terminal and touch it to the power connection on the solenoid to see if that powers it and I get the click noise with causing an issue?
