I just bought a used 5hp honda 4 stroke and it will not idle. it will run if you turn the idle screw up so it revs high but can not get it to idle low enough. when rpms go down it stalls. will idle kind of low with choke our. i checked the spark and replaced the plug and fuel filter. i put new gas in the tank and added some fuel stabilizer. i checked the fuel flow to the carb and ran with finger over end of hose going to carb and it seems to be building some decent pressure. i tried cleaning the carb. i removed it and took out main jet and air fuel screw and sprayed them with brake cleaner. i put it back together and it still will not idle. maby i just didn't clean it enough. is the an idle or low speed jet? i didn't remove item #10 in picture of carb parts below. any advise would be greatly appreciated.
http://www.boats.net/parts/search/Honda/Outboard Engine/0/BF5AH SA VIN%23 BADS-1000001 TO BADS-1099999/CARBURETOR/parts.html
