so im having a power trim issue on a 1997 150 merc, where both my remote switch and cowl switch both trip the relays but wont cause the motor to trim. If i connect my motor to direct power the engine will trim. So i believe the motor is good. I've replaced both relays and have checked continuity through the whole electric system and the highest resistance i found was from the remote switch to the relay harness it was .05 Ohm. So i would say good on wiring as well. At this point im at a loss on what to try next. What would you recommend i do?
