I have had this problem since I bought the boat and initially though it needed oil. When first raising or lowering the motor after its been sitting a bit the tilt almost looses power or struggles to raise or lower. After cycling up and down a few times it gradually gets stronger and operates as normal. I have filled the reservoir with atf per instructions. I have bleed what i beleive to be any air with cycling the manual valve open and running cylinders up and down. I made a little clip which shows majority of the problem though I was just using it so its not as bad as when its been sitting a bit. Before i tear things apart thought someone might know what is causing this. My guess is its the motor or possible relay. I appreciate any help.
Thanks.
Thanks.
