jimmyborisenko
Greetings from the Yukon territory. I have a problem with my Honda 50 hp (around year 2000 or a little later). Long story, but my boat broke free and got beached in big waves. Gravel and sand was packed against the transom and motor shaft (the motor was not submerged). After rescuing and cleaning all gravel and sand I could see around lift motor, I raised the motor with the power tilt switch on the motor. Near the top, I heard a little crunch of grave, and it stopped. And now the power tilt (either on the motor or the shift lever) doesn't work. I think I overworked the lift motor briefly. My first thought is a blown fuse, but I can't find a fuse. Do you know if there is a fuse someplace in that system, and if so, where I would find it? And if not a fuse, any other suggestions? The lift motor was replaced a few years back. I think it was in good shape and working fine up until the crunch against some gravel, which is someplace I can't see.
Just wanted to add, I have power to the motor (the motor will start)
