Sw.anderson
Hi everyone! My 95 Johnson fast strike 115 is giving me a fit. Here's the issue: the motor starts and idles great. You can bring the boat on plane and accelerate to approx 3500rpms. If you try to take it passed that point, the motor begins to bog down and will not accelerate. However, if you push the choke key in for a couple seconds, it will pick up and run great for a few seconds before returning to 3500ish Rpms or you push the choke again to keep it accelerating. After working on it some more yesterday, we tested the motor on the water and squeezed the primer bulb while running to see if the motor would pick up but that didn't help. The only thing that would make the motor pick up was pushing the choke key.
So so here's what all has been worked on:
new fuel lines on the engine (all the preformed ones)
rebuilt carbs
new high speed jets
rebuilt vapor separator with new needle
new primer seloniod cover and selector valve ( the old cover had a crack)
primer bulb was replaced when the issue was first noticed
Any thoughts???
rebuilt carbs
new high speed jets
Any thoughts???
