pinion height measurement
if your just swapping parts into different housing you will be good, only time you need to reshim is if you replace gears or driveshaft as this is due to housings are precision machined.
you misunderstood what I am asking for the pinion height is the height from the top off the lower unit to the center off the hole in the shift rod To work proper it has to be an exact length.any one know the right length or a J115PLSSB
Your question is -----What is the shift rod height ?--------------Just google it---------johnson shift rod height.----Very easy !
send me the sight where it tells me that height please I have goggled it for over 4 hours I cant find it. thought I new what I was doing must not.
Please see post # 5------all that is needed is there.-----I have the chart on my shop wall, but I am 2000 miles from there at this time.
