Part Number for BF5A Carburator Rebuild Kit
cernicalo1
Would anyone please advise what is the correct part number for a BF5A Carburator Rebuild Kit.
I have an essentially new engine which has sat for some time, and need to replace the float needle, and any other critical gaskets involved in sealing the carburator after the rebuild.
Thank you for your help!
Hi,
Welcome to the forum.
Honda doesn't sell a rebuild kit for these carburetors.
Actually, they are VERY simple and almost no "hard parts" ever need replacement.
A thorough cleaning and a gasket set is usually all that's needed to "refresh" one.
The older versions are almost the same as the newer ones but with some very slight differences.
You will need to have the year of manufacture or the outboard's frame number to ensure that you get the exact match (if available).for any item your carb might need or that you want to replace.
The "if available" applies to older versions as some items are no longer sold for those.
Below is a link to the newer version...2007 and later.
Note the tamper resistant cap/plug over the idle mixture screw. Item #5
The link below is for the 2001 version. Note the absence of the tamper cover for item #5.
www.boats.net is a good source for parts in the U.S. and the prices are lower than direct from Honda.
Happy to discuss any questions with you.
Good luck
