Hey y'all, so recently picked up a Searay with a Bravo one Drive. With the season closing out in my area im doing all the needed maint.. The drive was in pretty bad shape corrosion wise and it had to do with the Mercathode system not working properly. That's all fixed as of now, my question is I see a lot of people using Alodine to pretreat before primer. Because of the corrosion and i'm a stickler for appearance ive spent the last two days using Metal 2 Metal to fill the corrosion pitting AFTER sandblasting the drive. My question is can you use alodine over the M2M or did i screw myself by using the filler before hand? also any tips tricks or whatever you got would be greatly appreciated! Thanks!!
