I recently acquired a 2002 Honda BF50 with about 200 hours on it. I had the impeller and thermostat replaced along with other routine maintenance items so that I'd be starting with a "clean slate".
After about 2 hours running time I am having no problems running at partial or at full throttle. However, after a few minutes idling, the engine will sputter slightly, followed by the red light coming on and the overheat buzzer sounding. The water continues to stream out of the telltale (quite warm) but once the alarm sounds I can only cancel it by shutting the engine off and waiting a minute or so (rather than by just increasing rpm's to pump more water through). If I go back up to speed after waiting with the engine shut off there is no problem but if I then begin idling again, the overheat will resume after a couple of minutes.
Any ideas? I finally just got this boat into the water and the nearest Honda dealer is a long trailer ride away....so I'd prefer to try what I can on my own before I load it all up again!
