Old Vintage Merc
1985 Blue & White 9.9 B100 Honda. I was feeling really good about replacing all of the water seals in the lower unit and successfully reattaching the foot. I even got the lower filled with gear oil. Then it happened! I was trying to insert the pin connecting the shift rod to the shift linkage and I dropped the pin down into the shift rod channel. I'm guessing that if I remove the foot that the pin should fall out. Mind you just a guess. I doubt that the pin is even a ferrous metal to fish with a magnet, not that I could even even get one down there. Without admitting that you've ever done that could someone give me the low down on recovering the pin? Man I feel bad. So much effort and then I instantly dissolve all my accomplishments. Much appreciate a helping hand. Bruce
