**** I have been*a fan of this forum*for years, and now need your valuable help again.* I will give as much info as I can so please bear with me...I have just obtained a fresh water 19' 1994 Four winds 302 cobra (2 bbl) for almost free. It has many positives.* The boat has an excellent trailer, excellent*hull,*solid stringers, fair*interior,*very low hours (260), the*manifolds, risers, alt, 2 bbl carb, etc look almost factory*new, and the omc out drive is in excellent*shape and has no issues.*It started and ran fine on the hose in the driveway for 10 minutes*with no issues, so off to the lake we went, *it was soon was apparent when the*steam started coming out the pcv vents that it either had a bad head gasket or a cracked block..* Pulled the plugs, two on left side had water,* pulled the head, it has a cracked block..** bummer..**Here is where i need your expert help again,* I am a chevy man and know a whole lot about rebuilding gm's,* but not a lot*about fords..*** I don't know the different types of years*of ford 302 blocks out there that will fit with bolt patterns of heads, intakes, flywheel patterns, *etc....*
* Can you please get me headed in the right direction...
Money is a huge object here, (wife has tight purse strings).....* I would love to*get a marine*crate engine, but that will not happen...
Can you please get me headed in the right direction with what year/style 302*blocks fit this?
thank you again for all of your help.
