Ron Elliott
Hey everybody, haven't been on here in ages.
Not sure if this is the place for this but...
I have an older mercury longshaft 1500 (think its around 1979) that needs the power head rebuilt at least. No rod through the block visible at least, turns over.
No compression on cylinder 1 30 LBS on #3 and varying on remaining cylinders, I can't get my tester into #6 without removing lower housing but had significant amount with finger over hole.
I'm curious at to the estimated cost of honing or boring block and rebuilding this magnificent motor.
What I might spend on this might still be cheaper than buying a similar newer HP motor let a lone a 4 stroke?
