Hi,
Does this one have ignition points or CDI ignition?
The thing that might worry me most about messing with one of these old carburetors would be getting them sealed back up properly without replacement gaskets. I'm not averse to fabricating gaskets but these little darlings have some unique and odd shapes.
I wouldn't at all rely on being able to reuse any seal or gasket on that carb and I think it would be folly to do so anyway on something this old even if you thought you could get away with it.
Referring to the link below, the float chamber cover seal has a molded oring type seal with a flat section on one side. That might be difficult to duplicate with an oring repair kit. Doable for sure but could be a bit of a challenge to get it correctly refitted.
But the one that would intimidate me the most is the gasket between the float chamber and the main body. It is a very odd shape in the center.
It might be easy but, depending on how precise you'd need to be, it might really give you fits.
And, you won't really know until you can look at it directly.
I would try to be as delicate as possible to remove it in one piece.
Then there's the question of "who's been here before ya" and what have they done?
While I completely agree with checking/adjusting the valve lash on this old girl, The FIRST thing I would do is check to see that the choke valve returns to the fully horizontal position and stays there.
These are some TOUGH old classics and I hope you can get her "smoothed out" without too much bother.
Good luck.
