Hi Guys, I’m new here this is my first post so hope it’s ok.
I have a pair of honda 225’s 2006 build (but effected by Service Bulletin 70!).
I bought them 10 years ago with only 20hrs on them. They were winterized and stored. I finally got a hull last year and so in the process of rigging the boat (a 29 foot stepped RIB). Crazy but true….
Been reading bits and pieces on this forum over the past few months and am rather disappointed with Honda, corrosion where the port flush doesn’t reach, reading about SB70 and 56! Why didn’t Honda tell me about these design mistakes – too late now I guess for them to sort. Perhaps I should have followed the pack and gone with Mercury Verado’s….
Any way they have just been serviced and one started first time (amazing) the other took a few attempts (still amazing)! The boat should be ready for the sea in 2-3 months.
I also want to ask about maintenance and running in but I’ll do that under another post.
So the purpose of this post is to check what you would do regarding replacing parts – etc – bearing in mind they work with no faults (yet) they are just 10 years old but new, below is what I’m planning and have gained from this forum:
What I am planning to do: your opinion would be great (BTW I’m based in the UK but the boat will eventually go to a Greek island where good servicing is more tricky to find so I’m going for belt and braces now):
Richard
- Engine Oil (obviously).
- Gear Box Oil.
- Cam Belt (and check pullies for corrosion).
- Check thermostats (may just replace?) and check corrosion.
- Change high and low pressure filters (already done).
- Remove and check plugs – use non binding greece.
- Change water pump and check midshaft bearing.
- What are the views about service bulletin 70 – should I do – can anyone send it to me so I can double check the height is ok please? (pretty sure this hasn’t been done to my engines – is there anyway to check?)
- Also service bulletin 56 should I do and change the oxygen sensors – if I do I think I also need a new ecu (I assume these haven’t been done again anyway to check?). What do you think?
Richard
