Oil spitting out from pee hole.
TheHungryFisher
I have a Johnson 5.5 CD-18, I believe it's a 1961. I tried 50:1 fuel mixture and I have oil spitting out of the pee hole and smokes a lot. I am using a trash can with water in it for testing and tried tuning the carburetor and can't get it to run right. I believe the mix is supposed to be 24:1, but wouldn't that make it worse or no? Also the water is spitting out and not a stream.
If you just bought this motor you need to install a new impeller.------Powerhead must be lifted off to disconnect the shift rod to do this.-----Yes this motor has needle bearings on the con rod like models that run at 50:1.-----Post the compression test values here.----Original head gaskets were weak.----Replacements are improved with a metal ring.------If coils are original they will be cracked.-----Remove recoil .---Remove inspection cover and inspect coils through hole in flywheel.
If it has the original head gasket , I would remove cylinder head.-----The head will be warped and gasket may be leaking between cylinders.----Resurface the head and install a new gasket.
I cleaned it up a bit and sanded the head. What is the compression supposed to be?
Any close-up pictures of cylinder walls with piston at bottom of stroke ?-----I soak those thermostats in vinegar for a day.
Same direction as the motor turns.----Counterclock wise if you put impeller in housing first.-----Turn driveshaft clockwise if you put impeller on driveshaft first.
Coils don't look so good but the points do. Should I change everything? It still runs like that.
That is classic example of old coils.----They are scrap.----This means that motor was sitting around for perhaps 20 years or more.-----Every one of these motor has or will suffer this condition.-----Condensers and points are not original and may be OK.
I changed the head gasket and got less than 75. Could it be the rings?
First, I would never run a pre 1964 OMC on 50-1 oil ratio, my rule of thumb has always been, if it has an adjustable high speed jet, it's 24-1 on oil ratio. If its dumping oil out of the exhaust, it needs a tune up. Your cylinders look fine, rings may be stuck from 60 years of carbon, but compression is even so move on to a magento and carb rebuild plus a new water pump and gearlube. Total parts about $225 and she'll run perfect with guidance along they way. These were great engines, simple, reliable and with a liitle TLC you could give it to your grandchildren.
Parts for a 61 and 64 model might be the same.-------And a 1970 model 33 HP is shown with adjustable high spped needle.----So you would run that at 24:1 ratio?
For whatever reason, 1964 was the year for 50-1 on all of them. I stand corrected, you found the only big twin remaining that had an adjustable high speed jet in 1970. Actually the 1960 5.5 was still a bushing rod bearing engine and switched to needle bearing rods in 1961 but 50-1 was not recommended until 1964.
There was a kit available to put high speed needle on say a 1977 model 6 HP.-----Never mentioned to go to 24:1 if installed.
