Hello All,
My 1994 Mariner 115 hp 4 cylinder Serial number OG101768 has an oil injection system. I want to continue using it. I do not want to disable it. My question is, I noticed when the engine sits for a little while the fuel lines start to fill up with 2 stroke oil. I know this because I ran the engine dry of fuel and later connected the fuel line back up to the motor to run it again and a bunch of oil came out of the connecter when I was putting it together. Also, I use the motor to get up and down the lake, and use my electric motor most of the day. When I go to restart the engine, usually gives off a nice puff of smoke when I first start it, then doesn't smoke after that. Is this normal or is there a bad check valve or something in the system that may be bad. Thanks for your help.
