I've got a 1993 Ocean Pro 200, with a couple of carb related issues:
#1 when the engine is tilted up, oil appears to be leaking from the carbs and it seems to be burning more oil (excessive smoking from the exhaust) than usual.* What could be causing this and how do I correct it?
#2 to keep the engine running at idle, I need to keep the choke on.* If I release the choke, it stalls within a few seconds.
#3 when*I can keep the engine running and shift into gear (even after it's at temperature) it stalls as I add power.
Some of these problems I may have created.* To reduce the amount of excess oil in the mix I tried adjusting the lean/rich mixture.* I believe I got them all back into their original positions, but need a way to check that.* Can anyone tell me how to adjust them to their proper setting (BTW, my tach doesn't work)?
The engine has very low hours and sat idle through last year.
